I wanted to use Capella to demonstrate the consistency between system’s missions, its capabilities and its functions.
I depicted the missions and capabilities using the MCB diagram, and mapped (capability exploitation) between them.
Few questions:
- I wanted to associate them with the system, but couldn’t find how to do that. Any advice?
Since I could not do it, I created the only system related element which appears in the MCB diagram: Actor. I associated the specific actor with both the missions and the capabilities (using “involved actor”).
- I then wanted to show how the system functions (or at least functions implemented by the actor) related to the required capabilities. I could not find any diagram to do so. I could only find the SAB diagram to create the system functions, but could not find how to allocate them to the agent nor could I relate them to any capabilities. Any advice?
Thanks,
Avi
Thank you Stephane. I looked into the material you mentioned.
I now understand the implicit relation between a system and missions / components. However, I do wish to express it explicitly in a diagram (for communication with stakeholders). This is a gap.
Additionally, according the popular definitions, functions help to achieve capabilities, and are not necessarily a component of a capability. Functions (as system characteristics) enable the capability (an actor characteristic).
I suspect there is a gap in Arcadia with respect to this perception.
Regardless, how do I create a functional chain diagram to describe a capability with a functional chain? Could not find it in the tutorial (I guess because it’s a new feature).
Thanks in advance!
Avi
Hi Avi,
I did not say that Functions are a component of a Capability, I said they are used to describe them, and indeed in Arcadia Functions helps to achieve Capabilities, so I think we are aligned here.
If you want to communicate to stakeholders that Capabilities are System Capabilities, you can use a Note in your diagram.
There are different ways to create Functional Chains in Capella, and this is not a new feature. It is covered in the tutorial, for exemple here:
https://esd.sutd.edu.sg/40014-capella-tutorial/SystemAnalysis.html#Chain but you can also read the embedded Capella documentation I guess.
Thank for the pointer. Sorry I missed it.
However, I am still missing the explicit relationship (also between capability and function). I will look into this more thoroughly though.
Avi
That’s very helpful Stephane.
I will try to prepare something and maybe continue the discussion here with a meaningful example.
Thanks!
