Hi All,
Is there a way to set the default columns in the mass visualization/editing tables?
I know that the columns can be different depending on the element type.
I am a heavy user of the mass XX views and I always need the ‘id’ column which is common across all element types to help with Python4Capella scripts. However every time I create a view, I thin need to select the ‘id’ column to add to the view. I spend a lot of time doing this. If I can update the default columns one way or another that would be great.
Any ideas?
