Hello
My question is more enhancement request to tool makers:
Currently I use many csv export to analyze my model and I have several concerns:
- All views are forgotten when exiting the tool, so you need to perform again the selection. I exports have each time the same criteria: I need functions; functional exchanges Exchange Items; Modes; Capabilities…
When selecting, I have to select at once items to be sent in several views, by short lists du to their position in the tree: examples: capabilities; scenarios; function instances or function and functional exchanges. I would like to have a way to show them all together for selection.
The second choice would be to prepare a doc template, but then I would have to convert all tables to Excel to apply data checks (or Access)
All this is related to:
Check exchange item nature (which is set as property value group to allocating exchange category)
Check justification of allocation: EI is used in one IS at least relating to interface and invoked exchange
Track state and mode attribution while crossing Arcadia process from Mission; Capabilities to Component Behavior
Track variant (applied property value group) from applying to function instance; scenario; capabilities; functions; allocating components (Value and attributes)
Track generalization of EI values used in scenarios to signals through typing and generalization, track distribution of instances for EI related to multiple instanced function/components.
At the moment I exporting 24 different tables for all this, just for system analysis.
Thanks for any information
Thierry Poupon
