How to change the variable ‘self’ to other names?
How to change the value into other elements instead of the system engineering element? For example, I want the value to be the Physical Architecture so that I can write fewer expressions which is more convenient.
You willl need to change the type of the variable in the template. You can use the template properties wizard to do this.
Then you can select an element of this type in your genconf file.
