Hi all,
I have a question regarding to the requirements generation in M2DOC. I can print all requirements using the tracing relationship with other requirements bu if I want to print all requirements together with the requirement package, I do not know how do the coding. Anyone can help?
Thanks in advance
We are currently using the viewpoint requirements. But we want to start from the basic requirement option. What we want to do is just print out all the requirements under requirement pkg in a table.
Thanks a lot
Hello
You may want to try the Mass Editing or Mass Visualization views in Capella 1.3
You will be able to drag-and-drop the requirements to the table (cf. image), then export it to a CSV format (look at the small triangle at the left of the image)
Hope it helps
