I’m using Capella 5.2 with M2DOC 3.2.1.
For a different project I used an other generating tool, but now I have to come to M2DOC for a local project.
For this project I created a new template and modified it, to get my informations from the model.
Lesson learnt from the las time, I checked the capella package at the template properties ;-).
Nevertheless when I validate the template, no error messages will be generated. Also when “generate document” is operated.
Unfortunatly there are now many error messages in the generated file. It seems that the eAllContens() method does not find any objects.
I reduced my template to isolate the error, but I have no idea what is missing.
So I start to create a loop to create a table with all my OC:
Template
{m:for ocp | self.eAllContents(oa::OperationalCapabilityPkg)}
{m:if cop.name=‘meinName’}
(tableHeader)
{m:for oc | ocp.eAllContents(oa::OperationalCapability)}
(tablerows)
{endfor}{endif}{endear}
Result
So far so good. Validation states no errors, generation states finished with no errors.
When opening the doc, this is the content:
eAllContents(org.eclipse.emf.ecore.EObject,org.eclipse.emf.ecore.EClass) with arguments [null, org.eclipse.emf.ecore.impl.EClassImpl@ad620fd (name: OperationalCapabilityPkg) (instanceClassName: null) (abstract: false, interface: false)] failed: null java.lang.NullPointerException at org.eclipse.acceleo.query.services.EObjectServices.eAllContents(EObjectServices.java:1085) at org.eclipse.acceleo.query.services.EObjectServices.eAllContents(EObjectServices.java:1061) at org.eclipse.acceleo.query.services.EObjectServices.eAllContents(EObjectServices.java:1032) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.acceleo.query.runtime.impl.JavaMethodService.internalInvoke(JavaMethodService.java:162) at org.eclipse.acceleo.query.runtime.impl.AbstractService.invoke(AbstractService.java:135) at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.callService(EvaluationServices.java:129) at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.call(EvaluationServices.java:172) at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.callOrApply(EvaluationServices.java:208) at org.eclipse.acceleo.query.parser.AstEvaluator.caseCall(AstEvaluator.java:189) at org.eclipse.acceleo.query.ast.util.AstSwitch.doSwitch(AstSwitch.java:119) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:53) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69) at org.eclipse.acceleo.query.parser.AstEvaluator.eval(AstEvaluator.java:109) at org.eclipse.acceleo.query.runtime.impl.QueryEvaluationEngine.eval(QueryEvaluationEngine.java:52) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseRepetition(M2DocEvaluator.java:1415) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseRepetition(M2DocEvaluator.java:1) at org.obeonetwork.m2doc.template.util.TemplateSwitch.doSwitch(TemplateSwitch.java:147) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:53) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69) at org.obeonetwork.m2doc.generator.M2DocEvaluator.doSwitch(M2DocEvaluator.java:1450) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseBlock(M2DocEvaluator.java:1675) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseBlock(M2DocEvaluator.java:1) at org.obeonetwork.m2doc.template.util.TemplateSwitch.doSwitch(TemplateSwitch.java:199) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:53) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69) at org.obeonetwork.m2doc.generator.M2DocEvaluator.doSwitch(M2DocEvaluator.java:1450) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseDocumentTemplate(M2DocEvaluator.java:314) at org.obeonetwork.m2doc.generator.M2DocEvaluator.caseDocumentTemplate(M2DocEvaluator.java:1) at org.obeonetwork.m2doc.template.util.TemplateSwitch.doSwitch(TemplateSwitch.java:279) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:53) at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69) at org.obeonetwork.m2doc.generator.M2DocEvaluator.doSwitch(M2DocEvaluator.java:1450) at org.obeonetwork.m2doc.generator.M2DocEvaluator.generate(M2DocEvaluator.java:299) at org.obeonetwork.m2doc.util.M2DocUtils.generate(M2DocUtils.java:853) at org.obeonetwork.m2doc.genconf.GenconfUtils.generate(GenconfUtils.java:507) at org.obeonetwork.m2doc.genconf.GenconfUtils.generate(GenconfUtils.java:432) at org.obeonetwork.m2doc.genconf.editor.command.GenerateHandler$GenerateJob.runInWorkspace(GenerateHandler.java:87) at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:42) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Additional infos
I already tried to add nsURI from a template I used in 2022 for a different project, but with the same result.
Does anyone have an idea what I have overseen or where is the error Imade?
Thanks in advance and best regards
Carsten
