I’m using Capella 7.0.1 and M2Doc 4.0.1. on windows 11.
I want to use the M2Doc interpreter. The result HTML is using a black background with black font so unreadable. I well set the appearance to light theme on capella
Do you use the dark them for your Windows 11 ? That’s the first time I see that, but the web browser used for rendering is probably initialized with the default values from the OS.
If you insert some HTML via a service, it can also change the background color.
You can also switch the web browser from the preferences:
