I am generating documentation from a model with M2DOC. Some diagrams are meant for buiding purpose only and should not appear in documentation. I have set the property “Visible in documentation” to false, but the diagrams still appear in documentation.
What should I do ?
Thank you,
Best reagards.
Unfortunately, the property “Visible in documentation” is not yet support by M2Doc.
I have created a feature request for this point:
https://github.com/ObeoNetwork/M2Doc/issues/289
For now, what you can try is to put a key word in the name of the diagrams you don’t want to export (e.g. “[WORK]”) and to add a condition on the name of the diagram in your M2Doc template.
For this, you will need to use a nightly version of M2Doc (see this post for more information on how to get diagrams name with M2Doc:
https://forum.mbse-capella.org/t/499/).
You could then have something like this in your template:
PS: I’m not 100% sure of the syntax as I haven’t tested it on my side…
Thank you for your answer.
Best regards.
