The new M2doc release is now available and compatible with Capella 1.3.x.
Details at the usual site:
http://www.m2doc.org/capella/
Samuel
I just gave it a try, I’m a newbie using M2Doc and I’m facing an issue migrating a model from Capella 1.2.2 in Capella 1.30:
M2Doc version mismatch: template version is 2.0.0 and current M2Doc version is 2.0.2
Could you please tell me how to update the template version ?
thanks,
Olivier
I solved my problem by editing the template properties, second page, there one can edit the M2Doc version
just in case someone got the same issue …
Olivier
can you please provide a way (a link) to download the update-site as a zip?
It is a problem (not possible) for many user to access an update-site directly with eclipse through a firewall.
Thanks a lot
I respinned the release and the problem should be fixed now.
the update site is at the same url:
https://s3-eu-west-1.amazonaws.com/obeo-networkaggregation-r eleases/capella-extensions/1.3.0/full
sorry for the inconvenience,
Yvan.
you can access a zipped version here:
https://s3-eu-west-1.amazonaws.com/obeo-networkaggregation-r eleases/capella-extensions/1.3.0/full/org.obeonetwork.capell a.update.full.zip
I’ll add this information on the web page
Thank you!
