Hello all,
how to configure M2DOC for capella 1.2.1?
I used the same configuration of 1.2.0, but not worked!!
thanks for help
The main difference between the two versions is mainly the migration of the IFE models. If you want a clean start you can update using the update site:
https://s3-eu-west-1.amazonaws.com/obeo-networkaggregation-r eleases/capella-extensions/1.2.1/full
Then reimport the IFE example. Or you can migrate the modele yourself and make sure the genconf is not broken before starting the generation.
regards,
Yvan.
I want to say as an element in capella as the ExchangeItems…
