Hi everyone,
i’m beginner in using M2DOc, i wanted to create a new template to begin the coding, but i was blocked in the creation part. I have browsed the project and workspace, but i couldn’t click on Next to create my new template. Thanks for helping.
You need to click the “Browse Workspace…” button then select your model (probably a .capella file). Then select an element from the model you want to use as starting point (at this stage it will be only used to know the type of element for the variable), set the variable name and click “Finish”.
After that you will need to create a .genconf file to launch a generation. If you want to export diagrams make sure the SiriusSession option reference the .aird file of your Capella project.
Thank you. i have tried it and it works
