I just find out that M2Doc 4.0.0 provides the capacity to define a notion of visibility on a template code block.
I assume that it would allow to define a template code block in one word template document, and reuse it in another word template, allowing to mutualize definition of small generic templace code block for different final templates.
However, I do not achieve to do this. The word template that I use for my documentation generation (the one configured in the genconf file) does not recognize the template code block that I can define in orther word template documents.
I guess that I would need to define some import or dependency between the word documents. But I couldn’t find how to do it in the M2Doc reference documentation…
Am I understanding this notion of template block visibility the wrong way?
If not, can you provide an example on how to do it?
Thank you
