Hi all,
I’m currently trying to modify the create_LAB_diagram script in order to define the positions of components created in the diagram
To do so I added a call to set_bounds function from diagram.py
# we define a function that will recursively walk the given LogicalComponent and it’s children to apply the given mapping.
def create_logical_component_mappings(parentContainer, logical_component, mapping):
for child in logical_component.get_owned_logical_components():
# the semantic element of the “LAB Logical Component” is the component Part
newContainer = apply_mapping(parentContainer, mappingComponent, child.get_java_object().getAbstractTypedElements()[0])
newContainer.getSemanticElements().add(logical_component.get_java_object())
set_bounds(newContainer, [10, 20, 50, 80])
# we call the same function on the child LogicalComponent
create_logical_component_mappings(newContainer, child, mapping)
And then encounter the following error: “the given diagram element has no GMF node.” Because eInverseByType does not find any object referencing the created container
It seems that the created DNodeContainerSpec (newContainer) is not “fully” created
I’ve tried adding a call to a refresh (org.eclipse.sirius.diagram.business.internal.dialect.DiagramDialectServices().refesh(…)) without any success
How could I set up the bounds of a component in diagram created through script?
Thanks in advance
You will need to open the diagram in Capella for Sirius to do its magic. Some DNode or DEdge might be recreated and GMF nodes will be attached. This process need information from the Display, that’s why it can’t be done without opening the diagram (as far as I understood). Depending on the depth of elements and which elements are visible, you might need to do this many times:
editor = Sirius.open_representation(my_diagram.get_java_object())
print("Openining diagram", my_diagram.get_name(), end="")
while editor.isDirty():
print(".", end="")
model = CapellaModel()
model.session = Sirius.get_session(my_diagram.get_java_object())
model.save()
executeUI("org.eclipse.ui.PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().closeEditor(org.eclipse.ui.PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor(), True)")
print(" done.")
This will open and close the diagram editor several times and leave it opened at the end. That’s not perfect from a user perspective but it works.
Hi Yvan,
Thanks for the answer
I unfortunately work using old Capella and python4capella versions (4.5.2 and 1.2.0…), so I don’t have access to the Sirius.openRepresentation method
I’ve tried using “org.eclipse.sirius.ui.business.api.dialect.DialectUIManager.INSTANCE.openEditor” without success, the returned editor being null. It creates an empty tab only
Any idea about the way to open the editor in my versions context?
Thanks in advance
I don’t think it will be possible… You can try to install the last version of Python for Capella on your Capella (do this in a test environment). It should work.
The pointer to the Java code being executed. This might be transformed to be called from Python but I’m not sure how to pass variable from the Python script while executing the code in the UI thread… If you have a working example please post it here.
