Hello, I had one operationel Entity, that I transfered to a system actor.
That OE had a State machine associated to it,
Is it possible to transition that State machine aswell?
Yes it is possible:
So you can do it manually but not automatically, good to know though.
However, It does not seem to transfert it directly to the same entity.
Example: if you have an operational entity and you transition it into a system actor,
then when you do the process you shared with a state machine associated to the operational entity, it would NOT be transitioned to the system actor, it goes instead under “System”.
I wonder how that would work between Actor sytem and logical actor.
Anyway, now i need to find a way to transfert the “system” machine state to my “system actor”…
edit: Drag and drop works.
