Is it possible to make a certain viewpoint automatically when creating a new project?
Hello , i want the Capella viewpoint perspective to be automatically opened when i create a Capella project how i can obtain this?
Hello Mazen,
  • using emf framework, you can IWorkBench to get get active window
  • then use platformUI to set your perspective , you should get your perspective ID from plugin.xml file which will be in your UI plugin
    GoodLuck
