Hi
I try install in ubuntu 19.04 (x64) it have default openjdk 11 "
openjdk 11.0.4 2019-07-16
OpenJDK Runtime Environment (build 11.0.4+11-post-Ubuntu-1ubuntu219.04)
OpenJDK 64-Bit Server VM (build 11.0.4+11-post-Ubuntu-1ubuntu219.04, mixed mode, sharing)
but seems crash
Yes, Capella requires Java 1.8 64 bit to run (64 bit is important!), and ideally this version: JRE 1.8.0_121_64b, it won’t run on Java 11.
You can download and install the right version from this page (search for 8u121):
https://www.oracle.com/technetwork/java/javase/downloads/jav a-archive-javase8-2177648.html
Hope this helps,
Stéphane - Obeo
and how use it ?
also i add this eclipse.ini :
-vm
/pathto/jdk1.8.0_121/bin
not help me
I am not sure about that, let me try to get some help!
Another solution is to switch globally your java version thanks to update-java-alternatives, see its manpage for usage :
https://manpages.debian.org/stretch/java-common/update-java- alternatives.8.en.html
Mélanie
