Here is the procedure I used to package Capella 1.1.0
Unzip the downloaded ZIP archive
Make the eclipse file executable:
Rename the capella folder to Contents (for the structure of a MacOS App):
Drop the attached eclipse.ini file into Contents/eclipse/
Create the app container:
Move the Contents folder into the app:
You should now be able to launch Capella!
Hope it helps
I installed the software and followed the steps as said.But when I try to open the application , i get some error in the log file .Please guide me.
I followed the procedure to install Capella 1.1.2 on my Mac and ended up with this error:
“The Eclipse executable launcher was unable to locate its companion shared library”
Any help will be very much appreciated.
Wael
