We are using Capella as an MBSE tool for the concept design stage. Since a lot of projects have a similar set of base components, we use libraries to make the process quicker. In the libraries we create RECs and them import RPLs of these RECs as needed in the Logical and Physical Architecture of a project.
A problem that we are running into is that if we use libraries, we no longer have traceability between the logical and physical RPLs that we add into the project. We need to link each physical behavioural element by selecting the “realised logical component.” This means that each physical RPL has to be manually linked to logical components that are also coming from a library.
We were wondering - is there is a better method of preserving this traceability when we use libraries? Or is this method of using libraries not advised?
Udai
