I would like to know if there is a way to add an image as a note to a diagram.
Is it possible? If so, how can I do it?
Hi Luc,
No, you can’t add an image as a note to a diagram.
However, you can use images in the diagram description or customize elements’ appearance using an image.
You may use a constraint to do it.
Ok, thank you very much for your replies
