I am trying to generate html documentation from the model. I am using capella 1.1.2 and installed the XHTML Documentation Generation addon using the update site.
But I could not see the context menu for html generation on the aird file.
Am I missing anything?
Any help much appreciated.
Arun
Just to check: the model has to be opened for the html generation command to be visible. Is it the case?
Thanks Stephane for your reply. Yes, the aird file open and I can see the model diagrams. Right click on aird - html generation command not visible.
Here is my installation details showing the installed plugin.
It will be helpful if I could resolve this since it is important for me.
Arun
Which element of the project explorer are you trying to open the contextual menu from?
Could you please try to open it from a child of the aird file?
Christophe
I am trying to open from open it from contextual menu of .aird file.
Here is the scrshot of its child elements. I check for the child elements as well, but It doesn’t show for it as well.
Specifically, which element should I right click to get html generation command?
Can you try using the dropins version please.
Boubekeur.
I got it fixed. The problem was the menu doesn’t appear in “Capella studio” perspective which was the default. I changed to Capella perspective, now it is visible.
Thank you all for the help
Arun
Nice! Thanks for the tip! It may be helpful for other users.
Christophe
