How to set the hyperlink and the hint content when placing the mouse on the hyperlink?
For example, i want to set the hyperlink on the requirememt name. Its hyperlink will direct to the text of the requirement and its hint is also the text.
This issue has been fixed in M2Doc 3.3.2. If you are using one of the HTML services is will work out of the box.
If you are using the asLink() service, you can add a parameter for the tooltip:
'Mona Lisa'.asLink('Mona_Lisa.jpg')
becomes
'Mona Lisa'.asLink('Mona_Lisa.jpg', 'The Mona Lisa painting')
