How to set a realized Logical Component in a Physical Component with Py4C?
Thanks,
d
Thanks,
d
I’m not sure why this don’t work. But it can be a starting point:
lc = LogicalComponent()
pc = PhysicalComponent()
cr = create_e_object("http://www.polarsys.org/capella/core/cs/" + capella_version(), "ComponentRealization")
cr.setSourceElement(pc.get_java_object())
cr.setTargetElement(lc.get_java_object())
pc.get_java_object().getOwnedComponentRealizations().add(cr)
Maybe an other relation is needed or the fact that my objects aren’t connected to a Capella model is the cause of the issue…
Hello Yvan,
Many thanks for this script, it works and I succeeded in connecting more than 300 physical components to their realized logical component in 5 minutes even though I was afraid I had to do it manually !!!
see you
d
