When creating a script that interacts with a model using Python4Capella, we usually specify which Capella project the script should target through a “path” variable, such as path = "Project/Project.aird".
However, I would like to avoid having the user manually change the project name each time they run the script. I looked into this, and it seems that I cannot use the input() function in Capella to let the user type directly into the console.
Would you have any idea how I could handle this? Ideally, a dropdown menu listing the available projects would be the best solution.
Thank you in advance,
