I understand that state machines are related to components and not functions, but I would like to create modes and states, and assign specific functions to specific states or transitions.
For example, a mode could have 2 states and the transition between the states will be handled by some functions I have created in the system architecture. A different function could be responsible for a similar behaviour in another mode.
Is something like this natively possible in Capella without addons?
You can use modes on Exchanges scenario, so model which functions are used depending on modes. For example, in the IFE example, there is an ES diagram at the OA level.
It is possible on a FS diagram. The wizard is empty because you did not specify in your mode and state diagram that the function on which you want to add a mode/state is involved in this mode/state.
