I am implementing a plug-in in Java for Capela Studio. I am using PVMT plugin 70.7.0 to define new properties on my model.
The help provided by PVMT plugin (Section: “Property Values Management Tool Guide/User’s guide/External API” explain that PropertyValueManager.eINSTANCE provide the following method:
- setDataValue(AbstractProperty property, CapellaElement element, Object value)
- getDataValue(AbstractProperty property, CapellaElement element)
How do I find the AbstractProperty corresponding to the defined property ?
Should I use the Vpd model from the VpdRoot element to retrieve the AbstractProperty from its name and group name ?
Is their an existing API that does it ?
Thank you.
