I would like to know how to export the objects (functions, components, exchanges …) of a library referenced to a project together with the objects of the project?
thanks,
david
thanks,
david
What do you mean by “export?” Export to what?
A sample script that will list all logical components from a Capella project and its libraries in the console:
if False:
model = CapellaModel()
model.open(aird_path)
print("Project System:", se.get_name())
for lc in se.get_all_contents_by_type(LogicalComponent):
print(" - Logical Component:", lc.get_name())
for lib in model.get_referenced_libraries():
lib_se = lib.get_system_engineering()
print("Library System:", lib_se.get_name())
for lc in lib_se.get_all_contents_by_type(LogicalComponent):
hi,
I meant “extract data with py4C” and the script is exactly what I needed!
thanks
have a good summer
david
