How to document an Operational Analysis
Hi everyone,
I was wondering how you usually document your Operational Analysis for external reviewers or stakeholders who are not familiar with Arcadia, Capella, or MBSE in general.
I’m less interested in the specific software setup or implementation itself, and more in the overall structure, methodology, and way the Operational Analysis is presented and documented.
Thanks a lot!
Cheers,
Olli
Hi Olli,
You might want to post this question in the Arcadia section of the forum for better visibility.
regards,
Yvan.
Hi Yvan,
thanks a lot for the tip :slight_smile: I’m always happy about any advice regarding the forum and how things are usually handled here.
I’ve now reposted the question in the Arcadia section.
Olli
I’ve found it works best to keep the operational analysis linked directly to the operational capabilities and scenarios being evaluated, then capture assumptions and results in separate documentation. It keeps the model cleaner and makes it much easier for others to understand the reasoning behind the analysis later on.
Thank you very much for the input. That already helps.
