java.lang.UnsupportedOperationException
at org.eclipse.emf.common.util.BasicEList$UnmodifiableEList.add(BasicEList.java:908)
at jdk.proxy10/jdk.proxy10.$Proxy23.executeScript(Unknown Source)
Anyone knows how to create the componentports and componentexchanges correctly?
The containedComponentPorts feature is derived. To add a port you need to add it as input or output port. There is no Python API provided but you can use the Java API:
I have the same problem as Jayden, but when I try to use Java API, its functions doesn’t exist. It looks like it is not imported:
File “workspace://CreateCapa/VOBC.py”, line 67, in
File “C:\Users\consultant\Desktop\Capella\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\java_gateway.py”, line 1321, in call
File “C:\Users\consultant\Desktop\Capella\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\protocol.py”, line 330, in get_return_value
raise Py4JError(
py4j.protocol.Py4JError: An error occurred while calling o35.setTarget. Trace:
py4j.Py4JException: Method setTarget([class org.polarsys.capella.core.data.fa.impl.ComponentPortImpl]) does not exist
at com.sun.proxy.$Proxy25.executeScript(Unknown Source)
