Hi All,
Can somebody explain to me the significance of the grey physical components in the PA (as opposed to the yellow physical components and blue behavioural components).
I have tried using them as major physical elements of the system but there is a clash between whether a yellow physical component is part of a physical breakdown or deployed onto a grey physical component.
If they are used as discrete systems of interest (for example you may want to have an airborne system and a ground system) how do you describe exchanges between them because I cannot see how to create physical links between grey components, only physical breakdown (ie contained in).
JFAvi8
