Generating a document with all diagrams an descriptions
For a project I’m working on, I’d like to generate a document that contains all diagram images of a certain type (e.g. Operational Activities, Operational Capabilities, etc.) and then print the diagram description underneath each image.
From the example template I found that I can generate a single diagram image like this:
{m:myProject.eAllContents().representationByDescriptionName('Operational Capabilities Blank').asImage().setWidth(400)}
However, I’m struggling with how to scale this beyond “trial and error” on the diagram name.
Questions:
  1. The string 'Operational Capabilities Blank' seems to be the representation/description name. How can i find the discription name of a diagram?
  2. Is there a way to iterate all diagrams of a certain type (e.g. all Operational Capability diagrams) in a {m:for ...} loop and export them as images? Ideally something like: filter by diagram type / viewpoint / description, then .asImage().
  3. Once I have the representations, what’s the recommended way to print each diagram’s documentation/description text beneath it?
Any help or pointers to the right API/query patterns would be greatly appreciated.
Kind regards,
Gerjen
Hi Gerjen,
  1. You can select the diagram element by clicking on the background of the diagram. From here you can access its description name:
    In the Sirius interpreter view:
    aql:self.description.name
    In the M2Doc interpreter view:
    selection.description.name
    In both cases you can trigger the content assist with CTRL+SPACE. But to get a better understanding of the structure of the Capella model (semantic model) and Sirius model (diagrams), you can check their metamodels:
  2. You can get all instances of an EClass with the allInstances() service:
    viewpoint::DRepresentationDescriptor.allInstances()
    Then you can select ones with the right description name:
    viewpoint::DRepresentationDescriptor.allInstances()->select(r | r.description.name = '...' or r.description.name = '...')
  3. DRepresentationDescriptor is a technical element used to describe a representation without the need of loading it. From it you can access the representation itself with the representation EReference. The final loop should look something like this:
    {m:for descriptor | viewpoint::DRepresentationDescriptor.allInstances()->select(r | r.description.name = '...' or r.description.name = '...'}
        {m:descriptor.representation.asImage()}
        {m:descriptor.representation.name}
        {m:descriptor.target.oclAsType(capellacore::CapellaElement).description.fromHTMLBodyString()}
    {m:endfor}
    The target EReference references the semantic element (it can be any model element EObject but here we need to access features from a CapellaElement) from a representation element. the fromHTMLBodyString() service converts the HTML to docx. You can find a list of M2Doc services here.
I hope this will give you a better understanding on how you can use M2Doc and AQL.
regards,
Yvan.
Thanks for your response, this helps a lot.
You’re amazing!
