still in the operational phase in the OAS scenario
is it right to do this?
if autotest ko we do the maintenance otherwise we enter a loop that must execute all the time in this loop I will have activities that will be executed in parallel, action 1, 2, 3, 4 and a CBIT if my CBIT is KO I must go directly to maintenance otherwise we remain in the loop (which represents the operational
Hi @Hajar_TOUIL
To me your diagram means that either:
1: Autotest KO - “Maintenir systeme” is performed
OR
2: Loop through:
2.1a: Perform the action 1 (currently not specified) in parallel with 2.1b, 2.1c, 2.1d, 2.1e
2.1b: Perform the action 2 (currently not specified) in parallel with 2.1a, 2.1c, 2.1d, 2.1e
2.1c: Perform the action 3 (currently not specified) in parallel with 2.1a, 2.1b, 2.1d, 2.1e
2.1d: Perform the action 4 (currently not specified) in parallel with 2.1a, 2.1b, 2.1c, 2.1e
2.1e: Executer CBIT in parallel with 2.1a, 2.1b, 2.1c, 2.1d
THEN (inside the loop)
2.2 You may optionally (i.e. do this or do nothing) “Maintenir systeme”
Loop back to 2.1a
Currently you have to perform “Executer CBIT” in parallel to other par activities.
If this CBIT Is KO, then you maintenir systeme.
So I think this all makes sense!
Hope this confirmation helps, Josh
@JoshWedgwood Thank you so much this is exactely what i mean
