Following this page from january 2021 : Metamodel · eclipse/capella Wiki · GitHub
- It is said that the “open Type” wizard can be used to find the metamodel of a type.
To create a
PhysicalFunction, you will need to know from which metamodel part it is defined. UsingOpen Typewizard withCtrl+Shift+Tand writing the type, you will find its metamodel.For instance, with
PhysicalFunction, you will see org.polarsys.capella.xxx. pa .PhysicalFunction, meaning it is coming frompametamodel (Physical Architecture)
- The “open type” wizard is DESACTIVATED when you are under the Capella studio default perspective.
However it works if you are under a number of other perspective types such as : “plug in development” or directly inside Capella (if the dev environment has been established).
How is the open type wizard is supposed to be used in Capella Studio exaclty? It is supposed to show to the user the metamodel ( “you will see org.pola… .xxx.pa.PhysicalFunction”). How could we achieve that? Thanks.
- (Optional: any documentation on this “PaFactory” mentioned or factories in Capella/eclipse?)
My main focus is on the first question, the second one is optional.
