What aql expression could I write in a title-block to have the associated FilteringCriterion value (defined with the addon Filtering) of a logical component?
Thanks,
David
Thanks,
David
The filtering addon metamodels are defined here. You can also use the Sirius interpreter view (menu Window > Show View > Other… > Interpreter View) to explore available EClass and EStructuralFeature using the content assist (CTRL+SPACE). When selecting a CapellaElement (LogicalComponent, …) you should get all associated FilteringCriterion:
aql:self.ownedExtensions->filter(filtering::AssociatedFilteringCriterionSet).filteringCriteria
If you want to use this expression somewhere else you will need to remove the aql: prefix.
Many Thanks Yvan
Have a nice week
d
