Hello!
I’m trying to execute from a docker container the HTML export, but for some reason it can’t find my file .aird (But it does exist). Could somebody help me to see what I’m doing wrong? The project name is called ThreeDofXYZ and I’m using Ubuntu. Thanks!
WARNING: A terminally deprecated method in java.lang.System has been called
WARNING: System::setSecurityManager has been called by org.eclipse.osgi.internal.framework.SystemBundleActivator (file:/capella/plugins/org.eclipse.osgi_3.16.300.v20210525-1715.jar)
WARNING: Please consider reporting this to the maintainers of org.eclipse.osgi.internal.framework.SystemBundleActivator
WARNING: System::setSecurityManager will be removed in a future release
log4j:WARN No appenders could be found for logger (org.polarsys.capella.common.mdsofa.common.helper).
log4j:WARN Please initialize the log4j system properly.
09-16 04:13:35 ERROR project . does not exist!
09-16 04:13:35 ERROR Representation file ./ThreeDofXYZ.aird does not exist!
Unfortunately, I’m getting a similar error. You can see it’s being pointed to the ThreeDofXYZ project this time (rather than .), & yet it still says the project doesn’t exist.
09-19 01:30:06 ERROR project ThreeDofXYZ does not exist!
09-19 01:30:06 ERROR Representation file ThreeDofXYZ/ThreeDofXYZ.aird does not exist!
For context, this is the dir structure of where I’m calling the command.
