DavidP
24 September 2022 08:49
1
Many thanks for Python4Capella Fabulous addon!!
following the Exporting Values with Python4Capella - #10 by StephaneLacrampe item:
Extracts Requirements Attributes and Values
if req.get_java_object().getOwnedAttributes() != None:
for att in req.get_java_object().getOwnedAttributes():
print("- Attribute: “+att.getDefinition().getReqIFLongName()+”, value: "+str(att.getValue()))
I would like to export an enumeration value attribute like this (rather than a string value attribute):
could you help me to script it?
thanks
This API has been improved in the last release. You can now use:
for att in req.get_owned_attributes():
print("- Attribute: “+att.get_definition().getReqIFLongName()+”, value: "+att.get_value())
attr.get_value()
will return the value as its primitive type of the Java object corresponding to the EnumerationValueAttribute
value. You can then use value.getName()
Your loop could become something like this:
if attr.get_java_object().eClass().getName() == "EnumerationValueAttribute":
print("- Attribute: “+att.get_definition().getReqIFLongName()+”, value: "+att.get_value().getName())
else:
You can also create new Attribute
by passing the type of attribute you want:
Attribute(None, "StringValueAttribute")
Attribute(None, "IntegerValueAttribute")
Attribute(None, "EnumerationValueAttribute")
Attribute(None, "BooleanValueAttribute")
Attribute(None, "RealValueAttribute")
You can then set the value with:
attr.set_value(value)
Where value needs to be the primitive type of the attribute or the Java enumeration value:
str_attr.setValue("some string")
enum_attr.set_value(other_enum.attr.get_value())
DavidP
26 September 2022 20:19
3
I try to implement your script but it fails. I can extract StringValueAttribute, Boolean Value Attribute but it fails on a EnumerationValueAttribute (ProgressStatus has 8 values).
Sorry to insist but it is relevant for my needs. Any Idea?
dvd
Don’t worry, this kind of feedback also helps a lot to improve Python4Capella.
And this is indeed a bug on Attribute.get_value()
for EnumerationValueAttribute
You will need to add some methods to the ReqIFElement
class and add a EnumValue
class:
class ReqIFElement(EObject):
if java_object is None:
JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "ReqIFElement"))
elif isinstance(java_object, ReqIFElement):
elif get_e_classifier("http://www.polarsys.org/kitalpha/requirements", "ReqIFElement").isInstance(java_object):
else:
raise AttributeError("Passed object is not compatible with " + self.__class__.__name__ + ": " + str(java_object))
def get_id(self):
return self.get_java_object().getReqIFIdentifier()
def set_id(self, value):
self.get_java_object().setReqIFIdentifier(value)
def get_long_name(self):
return self.get_java_object().getReqIFLongName()
def set_long_name(self, value):
self.get_java_object().setReqIFLongName(value)
def get_description(self):
return self.get_java_object().getReqIFDescription()
def set_description(self, value):
self.get_java_object().setReqIFDescription(value)
class EnumValue(ReqIFElement):
JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "EnumValue"))
elif get_e_classifier("http://www.polarsys.org/kitalpha/requirements", "EnumValue").isInstance(java_object):
else:
Then you can replace the Attribute.get_value()
def get_value(self):
if self.get_java_object().eClass().getName() == "BooleanValueAttribute":
return self.get_java_object().isValue()
elif self.get_java_object().eClass().getName() == "EnumerationValueAttribute":
return create_e_list(self.get_java_object().getValues(), EnumValue)
else:
return self.get_java_object().getValue()
This will return a list of EnumValue
when called on a EnumerationValueAttribute.
Let me know if it helps. I also opened this issue:
opened 07:57AM - 28 Sep 22 UTC
You will need to add some methods to the `ReqIFElement` class and add a `EnumVal… ue` class:
else:
def get_id(self):
else:
Then you can replace the `Attribute.get_value()`:
else:
This will return a list of `EnumValue` when called on a EnumerationValueAttribute. For more details see [this discussion](https://forum.mbse-capella.org/t/exporting-enumerationvalue-attribute-of-a-vp-requirement-with-p4c/5744).
DavidP
29 September 2022 15:06
5
I’m sure that it is the last issue
get_value() seems to work for ‘EnumerationValueAttribute’
but getName() No:
last help?
merci!
dvd
On a EnumerationValueAttribute
get_value() returns a list of EnumValue
so you should write something like this:
for enum_value in attr.get_value():
print(enum_value.get_long_name())
DavidP
30 September 2022 08:09
7
Wunderbar!
I should have found the solution by myself…
Thanks for all
dvd
