is there any solution to this? My diagrams will be all large starting from logical architechture I can’t make them simple diagrams because my system is complex. I also avoided repeating functions, unless it’s really necessary (like same function but diffrent components)
I’m not sure I can help you with this specific problem. It sounds like a software bug to me.
However, I would suggest you reflect and consider whether you could reduce the complexity of your diagram. One of the many benefits of modelling is that you can abstract away complexity to make it more comprehensible. There are a number of strategies you could adopt to achieve this and Capella has some great features that help such as synthetic functional exchanges and categorization.
I’m sure that with some thought you could break a single LA view in to multiple LA views each with its own particular focus of interest that makes your proposed system easier to understand. Complexity often allows obvious problems with your design to hide in plain view. As systems engineers and modellers we should be motivated to reduce this possibility. This SEBoK page has a useful introduction to this topic.
Thank you so much, what you wrote is so helpful and meaningful I much appreaciate it; yeah right I once watched a video where somebody talked about those categorization, I will seek how to do it and if you have any useful tutorial about categoraization please leave me the link here. Have a wonderful week!
I wanted to update that I found a solution to big sized diagrams, apart from categorization could be amazing but I still didn’t know how to do it , so the solution is to tick export as html and then the diagram will be split into parts of images and then to simply merge them with an app (Miro for example), and the html file can also be used of course
