Hi There,
As we can define Data types as per example to be use in functionnal exchanges, can we export them as a data Model as XSD, as it is the same goal : modeling then produce a revelant image to software architects.
This could vbe very useful even if a technical reformatting afterward is necessary to fit the xsd decorum used in each project of course.
I noticed the xml export facility for “Data Package”, but it doesn’t seems to enable a XSD easily after I made a quick try (more dedicated to export the capella inner model structure of the object tree rather than the only designed data.
Some works in progress for that kind of feature ?
… bonus : what about about the import of a XSD ?
Best regards.
