I am encountering an issue when trying to manipulate elements of type ExchangeItemAllocation in my code. When executing it, Py4J throws the following exceptions:
py4j.protocol.Py4JError: An error occurred while calling o1171.getTransmissionProtocol. Trace:
py4j.Py4JException: Method getTransmissionProtocol() does not exist
and
py4j.protocol.Py4JError: An error occurred while calling o1171.getAcquisitionProtocol. Trace:
py4j.Py4JException: Method getAcquisitionProtocol() does not exist
Is there a known workaround or a recommended way to access these properties?
Here is the relevant part of the code causing the issue:
def get_interfaces(root_parent, behavior_component):
if behavior_component.get_implemented_interfaces():
implemented_interfaces = behavior_component.get_implemented_interfaces() # Interface[*]
for interface in implemented_interfaces:
exchange_item_allocation_list = interface.get_owned_exchange_item_allocations() # ExchangeItemAllocation[*]
for exchangeItemAllocation in exchange_item_allocation_list:
xml_exhangeItem_tree = etree.SubElement(root_parent, "Published")
transmissionProtocol = exchangeItemAllocation.get_transmission_protocol() # String
print(transmissionProtocol)
acquisitionProtocol = exchangeItemAllocation.get_acquisition_protocol() # String
print(acquisitionProtocol)
exchangeItem = exchangeItemAllocation.get_allocated_item() # ExchangeItem
xml_exhangeItem_tree.set('Name', exchangeItem.get_name())
xml_exhangeItem_tree.set('ExchangeMechanism', exchangeItem.get_exchange_mechanism())
get_all_exchange_item_elem(xml_exhangeItem_tree, exchangeItem)
Thanks in advance for your help!
