I have observed the following behavior with the “Show Functional Exchanges [ExchangeItems]” filter on functional chain descriptions:
When I add the ExchangeItems to a functional exchange and apply the mentioned filter, the label of the involvement of the functional chain will display all the ExchangeItems in square brackets even if you don’t assign any ExchangeItem to that particular involvement as Exchanged Item.
If I assign a specific exchange item to the FE involvement in the “ExchangedItems” field, it will only display the EI assigned to the involvement:
I think that, on the first image, the right behavior would be to not show any exchange items in the square brackets since they are not defined. Is that correct? Should I open a bug report for this?
