I’ve a issue with function import, someone know why when I try to import a function def customized in code editor get as error
_pyease_string_types = (str,)
File "workspace://Python4Capella/utilities/CapellaPlatform.py", line 50, in getAbsolutePath
except ImportError:
AttributeError: 'NoneType' object has no attribute 'getLocation'
\anaconda3\lib\site-packages\pandas\core\strings\accessor.py", line 236, in _validate
raise AttributeError("Can only use .str accessor with string values!")
AttributeError: Can only use .str accessor with string values!
Thanks in advance
