I have empty spaces that has been created after some operations in a sequence diagram, but i have no idea on how to delete this useless space.
Do you have any idea ?
Thanks,
Edgar
Thanks,
Edgar
Hi Edgar,
If you only select one of the lifelines and try to drag up, it doesnt work. If you have selected all the lifelines it works.
Scroll to bottom (note the little horizontal lines at the bottom of the lifeline):
Select the bottom of the lifelines:
Drag up the page - see that the outline view shows the lifelines are now shorter.
Thank you for your quick reply !
It seems to be working but when I drag up the page, a group of executions and sequence messages goes down. So i need to do it several times to delete this empty space
