Let’s take the example of a table generated through the Edition Table Description as follows:
The column “Test2” contains the descriptio of the element.
In instance, the description of the component LC5 is as follows:
It contains 3 sentences, which are separated by LINE BREAKS.
The text contain hidden HTML elements but that is not a problem right now.
The real problme now is, wether there is HTML tags or not, the line breaks remain, and these line breaks make the csv file generated (and then opened by Excel), lose its first configuration, In this example each Logical Component, instead of being described in one sigle line, they are described in multiple lines:
| Test1 | Test2 | |
| c3be4fb2-0281-4798-a44a-2e646d27aa7e | LC 5 | ' Line1 |
NewLine1 |
AnotherLine1 |
| 23bb0e05-c858-4bc5-b8e3-000a971a2c26 | LC 6 | ' Line2 |
NewLine2 |
AnotherLine2 |
| 881ed41e-7ef7-4c85-845e-a2fe4d340422 | LC 7 | ' Line3 |
NewLine3 |
AnotherLine3 |
(Image version:
I added the borders manually.
Question: is there any way to keep the description of the items while maintaining a normal version of csv/excel? (not breaking them into multiple lines) → To sum up, is there a way to make the transition from an edition table to csv, not take in account the line breaks inside the column “test2t”?
