Hi All,
I recently went from Capella 1.3.0 to 1.4.0. With this version, I cannot copy a graphic element from a diagram and paste it into an Office Word file. When I click on a graphic element with the right mouse button and select the “Edit” command, the “Copy” command appears disabled in the window that opens. Is it possible to make it active?
Thanks in advance,
Gabriele
I didn’t know this feature. I guess it was provided by the behind platform ‘Eclipse’.
The known way to export image in Capella is to use the export diagram as image button at the top of the toolbar on a diagram. It allows to export as png, jpg or svg the diagram.
In Windows 10, there is now a built-in screen capture using Windows+Shift+S.
It will allow you to take a screenshot of a part of the screen then you will be able to paste it in the word document.
https://support.microsoft.com/en-us/help/4043948#section-10
Philippe
