Is there actually a way to edit an operational process, e.g. adding a new operational activity to it? Up to now, I was not able to identify a way to do so except removing a process and then defining it again. So, I’m wondering whether there is an easier way?!
Hi Borys,
You can edit an operational process in an Operational Process Description (OPD) Diagram. Create one by doing right click on the operational process you want to edit, then “New Diagram / Table” and “Operational Process Description”. In that diagram, you can add the operational activities and the interactions you want.
I hope this will do it, because I know no other way.
