I am using M2Doc to generate the documentation associated to an Operational Exchange Scenario. This topic can be extended to any other interaction.
I am able to select all messages exchanged selection.eContents(interaction::SequenceMessage)
but I am not able to associated messages to the operand of the combined fragment they belong to.
Is there any way by querying the model or the Sirius diagram?
I can’t find any link in the Capella model nor the Sirius diagram… I think you will need to use some code from the sequence diagram from Sirius and write a Java service with it. I had a quick look and found ParentOperandFinder that might do what you want.
