Some times after having entered the description of some capella element, e.g. an Exchange Item or a State Fragment, the description is not there anymore when I reopen it. More often there is only the first letter of the description showing. Is this a known issue?
this bug has been identified and it is fixed in both Capella 1.2.2 and next 1.3.1.
Use Case:
- Double click on an element
- Select tab description
- Type some texts here
- Click directly the “Finish” button
- Only the first character is kept.
Michel
What is the release date of the 1.3.1 version?
The official version will be available at end of June, and freezed before mid June.
For tests, a stable version (release candidate) is available at
https://download.polarsys.org/capella/core/products/stable/1 .3.1-S20190515-151169/?d
Michel
The easiest work around for this is to remember to hit save before you click finish, the descriptions are then always retained (For me anyway)
