For the DARC addon, I would like to customize the Threat.kind as described in DARC Viewpoint usermanual
- I’ve created a folder “Cybersecurity Configuration” under the Operational Analysis but also tried in under System Analysis. Somehow in the example it seems to ‘sit’ somewhere else.
- I added the properties for Threat.Kind (event tried Thread.Kind as in the usermanual).
- Restarted Capella to start using the property.
However I cannot get it working as described in the usermanual.
Does anybody have a tip?
- Where does the folder “Cybersecurity Configuration” need to be?
- In the example it seems to be in the project scope instead of in one of the layers.
I am using capella 6.1
Maybe the “Crowd Surveillance System in DARC” project can have one property defined as an example.
