Hi.
I just created a plugin for a custom validation rule using the Tutorial at
https://wiki.eclipse.org/Capella/Tutorials/Extensibility/Validation_Rules
After meddling with the Capella Studio settings I was able to have a project free of errors and warnings and generate the .zip with the .jar plugin file.
I installed it in the Capella 1.4.0\eclipse\dropins\plugins folder as stated in the Tutorial.
Tried to check in Capella but it doesn’t load the plugin. I checked the Validation rules to see if the rule was added and it wasn’t there. I checked the Error log and couldn’t find anything related to the plugin. I searched for my plugin on the list in About Capella > Installation Details > Plug-ins tab and nothing. It seems to be completely ignored.
I’d like to know if there’s any way I can make Capella load (or try to load) the plug-in I created…
Hi.
I’ll add more information to help people engage in this post
About the project I built in Capella Studio (KitAlpha):
MANIFEST.MF file contents:
The CapellaTutorialValidationRule.java file contents:
My plugin.xml file contents:
My build.properties file contents:
Can anyone see a problem here? Using Capella [Studio] v1.4.0
Hi Fabio,
I think the issue is in you MANIFEST.NF file. It is missing the dependency to org.eclipse.emf.validation. (and you have declared quite a few dependencies that are not required, but it should be blocking though).
Here is my MANIFEST.MF file, I did the same thing as you and it worked:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: MyValidationRule
Bundle-SymbolicName: MyValidationRule;singleton:=true
Bundle-Version: 1.0.0.qualifier
Automatic-Module-Name: MyValidationRule
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Require-Bundle: org.eclipse.emf.validation;bundle-version=“1.8.0”,
org.polarsys.capella.core.validation;bundle-version=“1.4.0”
Export-Package: myfirstvalidationrule
Hi Fabio,
Hi Stephane, thanks for your response,
I added the ‘org.polarsys.capella.core.validation;bundle-version=“1.4.0”’ line to my MANIFEST.MF file but it still did not work.
Then I noticed the Require-Bundle header in my MANIFEST.MF file was different of yours:
Require-Bundle: org.polarsys.capella.core.validation;bundle-version=“1.4.0”,
I replaced with yours and it worked! Thanks a lot for the help!
Also, I noticed I posted this Capella-Studio related question in the Capella-General forum, if you are or know the moderator, I’d like to request this topic to be moved to the Capella-Studio forum, if possible.
Thanks again!
Thanks again!
Well, I may be wrong, but your question is related to adding validation rules to Capella, I would see it in the Capella workbench forum
Do you have exported your jar using “File > Export > Plugin Development > Deployable plug-ins and fragments” ?
The “File > Export > Java > JAR” doesn’t export a plugin that can be installed directly on Eclipse dropins folder.
I have updated the tutorial for this step.
https://github.com/eclipse/capella/wiki/Create-Addons#export-as-deployable-plugin
Philippe
Philippe
Hi Philippe, I used “File > Export > Plugin Development > Deployable plug-ins and fragments”, thanks for your answer and updating the tutorial!
By the way,
I’ve already fixed the issue by following Stéphane’s directions. It works great!
By the way,
