Hello python4capella community! I’m trying to generate physical ports on a generic physical component, but every time I try it I get several errors. There are many predesigned scripts but none of them create several physical ports on a physical component, can you give me a hand, has anyone tried it before? Thanks in advance.
Hi Alex,
There is no Python API for this but we can call the Java API from Python:
pc = PhysicalComponent()
pp = PhysicalPort()
pc.get_java_object().getOwnedFeatures().add(pp.get_java_object())
org.polarsys.capella.core.model.helpers.CapellaElementExt.creationService(pp.get_java_object())
You will have an error on the org symbol because it’s not recognized by PyDev but will be accessible at runtime. You can remove this error.
Note: you need to make all your changes in a transaction.
Thank you very much for your quick response! This code works fine, but I’m unable to achieve the same result that by doing it manually.
My code is:
if False:
if False:
from openpyxl import *
aird_path = "/TEST/TEST.aird"
xlsx_path = "/Python4Capella/InputFiles/Components.xlsx"
model = CapellaModel()
model.open(aird_path)
pc_pkg = se.get_physical_architecture().get_physical_system()
model.start_transaction()
try:
pc = NodePC()
pc.set_name("Comp1")
pc_pkg.get_owned_physical_components().add(pc)
pp = PhysicalPort()
except:
model.rollback_transaction()
raise
else:
model.commit_transaction()
# save the Capella model
model.save()
This code creates a physical component (Node) with one physical port. My problem (using Capella 5.1) is that I’m unable to see the proper graphical representation in a [PAB], I cannot see the graphical representation of the physical port itself and the proper relation in the semantic browser. So I don’t get the same effect that doing it manually, I tried everything but I just dont get how to do it. Do you have any idea why this is happening?
Thanks in advance!
Can you try to manually refresh your diagram ? I’m not sure if it’s enough for creating the visual representation of the port.
Yes it worked! Thank you very much for your fast response!
