Creation of physical links with python4Capella
Hello python4capella community! I’m trying to generate a physical link between two physical components, but every time I try it I get several errors. There are many predesigned scripts but none of them create physical links between, two PC can you give me a hand? Thanks in advance. I have only two components with one physical port each (PP 1 and PP 1_1), I try the following code:
if False:
if False:
from openpyxl import *
aird_path = "/TEST/TEST.aird"
model = CapellaModel()
model.open(aird_path)
pc_pkg = se.get_physical_architecture().get_physical_system()
model.start_transaction()
try:
    PL = PhysicalLink()
    PL.set_name("Cable1")
    for elem in se.get_all_contents_by_type(PhysicalPort):
        print(elem.get_name())
        if elem.get_name() == str("PP 1"):
            PL.get_java_object().getLinkEnds().add(elem.get_java_object())
        if elem.get_name() == str("PP 1_1"):
    PL.get_java_object().getOwnedFeatures().add(PL.get_java_object())
    org.polarsys.capella.core.model.helpers.CapellaElementExt.creationService(PL.get_java_object())
except:
    model.rollback_transaction()
    raise
else:
    model.commit_transaction()
# save the Capella model
model.save()
I get the following error that I cannot understand:
  File "workspace://Python4Capella/CODE/TESTS.py", line 36, in <module>
    from six import integer_types as _pyease_integer_types
  File "C:\Users\\\PROGRAMS\CAPELLA\CAPELLA_PROGRAM_FILES\..\..\..\..\..\..\Application Data\Orchestra\Capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\java_gateway.py", line 1322, in __call__
    answer, self.gateway_client, self.target_id, self.name)
  File "C:\Users\capella\..\..\..\..\..\..\Application Data\Orchestra\Capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\protocol.py", line 332, in get_return_value
    format(target_id, ".", name, value))
py4j.protocol.Py4JError: An error occurred while calling o196.getOwnedFeatures. Trace:
py4j.Py4JException: Method getOwnedFeatures([]) does not exist
	at com.sun.proxy.$Proxy71.executeScript(Unknown Source)
It says that getOwnedFeatures() does not exist, I really dont know how to add the physical link in a proper way, how can I solve this? Thanks in advance.
A way to create PhysicalLink is the following code:
print(se.get_name())
try:
    PL = PhysicalLink()
        if elem.get_name() == "PP_source":
            component = elem.get_container()
            print(component)
        if elem.get_name() == "PP_target":
    component.get_java_object().getOwnedPhysicalLinks().add(PL.get_java_object())
    print("created physical link created under :"+component.get_name())
except:
    raise
else:
model.save()
Thank you very much for your response Licia. It has worked very well for me! However I would never have guessed the getOwnedPhysicalLinks() or get_container() method, is there any place where I can look up all these methods to modify as many parameters as possible? Thanks again for your time and help.
One way to see which method to call is by the Sirius interpreter, go to Window->Show View ->Other->Other-> Interpreter->Open, then in expression write aql:self . More info Acceleo (eclipse.dev) , also in the forum itself there is more information on how to use the interpreter.
Thank you very very much Licia for your fast and accurate response!
